跳转到主内容
The Magnavox MDV2300 is a progressive scan-capable DVD player.
3 个问题 查看全部
Will not play dvds,
Even though i have played a dvd that it was played before, it will just continue to say disc error. I think (actually i am almost positive) i have to clean the laser lens from the research i have done online. I wanted to know if there is a way to clean it without having to buy that software
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @ariasatlas ,
Just verifying that you have tried other known working DVDs and they didn’t work either?
If so, software doesn’t clean the lens. You need to physically clean the lens
You have two options:
a) Purchase a DVD lens cleaning disc (example only) and use it to clean the lens. Just search online for other suppliers that may suit you better.
b) Use the ifixit MAGNAVOX MDV2300 Motherboard Replacement guide to open the player to gain access to the lens and gently clean it with a Q-Tip moistened with Isopropyl Alcohol 90%+ (available from most electronics parts stores).
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
Arias Atlas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 672
