跳转到主内容
修复你的物品
维修的权力
商店
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
493 个问题 查看全部
Fast charger charges other devices, but not one particular phone.
I have a customer who has a Galaxy S6 with a fast charger. The fast charger charges other Samsung devices quickly, even with the same cable. Has anyone seen this be a charge port issue before? I have only seen this as a cable or charger adapter.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
已选择的解决方案
This charging problem is fairly common I think. It is to do with a faulty charging port. You will have to get the charging port replaced and it will work fine. I used to have this problem I temporarily fixed it by putting a toothpick in the charging port and prying the thing inside th charging port up a little but I definitely wouldn’t recommend this. Better safe to just get a charging port replacement
这个答案有帮助吗?
得分 2
评论:
Yeah sounds like charging port needs to be replaced. OP should make sure it gets done via soldering replacement and not the daughterboard replacement as that is high risk in damaging the screen.
完成的
As my bio states, I've been in the business for over 2 years, and my company seems to have good luck with pulling the screen for the ports. Thank you both for your help.
完成的
添加一条评论
添加你的答案
Charlie B 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 36
