跳转到主内容
加入维修社区 - 创建账户
New battery on MacBookPro not recognized
I just replaced my battery on my MacBook Pro 13" Retina Display Early 2013, that I purchased from iFixit. The battery is not being recognized. The machine powers up fine when plugged in. When I boot and get to the login screen it shows the battery symbol with a white X. When I login and access the System Preferences/Energy Saver/Battery, the battery shows 0% and clicking on "show battery status in menu bar" does nothing.
I already opened the machine back up to reseat the battery connector but not luck.
Can someone please suggest things to try?
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Lets try doing an SMC reset How to reset the System Management Controller (SMC) on your Mac
Update (09/10/2018)
Oh No!
OK, lets double check things. run this app coconutbattery and post a snapshot of the apps window here for us to see with the charger plugged in 在已经存在的问题里加入图片
Update (09/10/2018)
@tate16t- OK, the MagSafe adapter appears not to be connecting. What is the color of the MagSafe connector’s LED Amber or Green? Just to be sure you did take the snapshot with the MagSafe connected correct?
Review this Apple T/N to make sure you have the correct MagSafe adapter and the cable & connector surfaces are in good shape Apple Portables: Troubleshooting MagSafe adapters and lastly you may need a new DC-In Board, here’s the IFIXIT guide MacBook Pro 13" Retina Display Early 2013 MagSafe DC-In Board Replacement and here’s the needed part MacBook Pro 13" Retina (Mid 2012-Early 2013) MagSafe 2 DC-In Board
This part connects the AC wall adapter power to the logic board.图片
产品
$29.99
MacBook Pro 13" Retina Display Early 2013 MagSafe DC-In Board图片
指南
难度:
中等
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
这个答案有帮助吗?
得分 2
11条评论:
I tried these steps with power connected:
If the battery is nonremovable:
Choose Apple menu > Shut Down.
After your Mac shuts down, press Shift-Control-Option on the left side of the built-in keyboard, then press the power button at the same time. Hold these keys and the power button for 10 seconds.
If you have a MacBook Pro with Touch ID, the Touch ID button is also the power button.
Release all keys.
Press the power button again to turn on your Mac.
Once I release all keys the machine powers on. The battery is in the same state.
完成的
I guess you'll need to get a replacement battery. Give the IFIXIT store a call or email them for instructions to get a replacement. Store contact Info
完成的
Thank you Dan. I will do that.
完成的
Hey Dan,
I’m sorry to report that my replacement battery is now showing, ‘Service Battery’.
Can you please suggest what I should do?
Thank you
完成的
The MagSafe was not connected. I guess it should be?
完成的
显示更多的6条评论
添加一条评论
Thanks Dan. I received a replacement battery and installed it last night and everything is working fine. Thanks for your help!
这个答案有帮助吗?
得分 1
1条评论:
was it just a faulty battery then?
完成的
添加一条评论
添加你的答案
Robert Tate 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 1,000
