跳转到主内容
Repair guides and support for your Samsung TV.
2610 个问题 查看全部
Black Screen Error light 5 double flashes then repeat
Samsung UN60D7000VF. Lightening ??
Black screen, no startup, only 5 double flashes of the red error light, pauses then repeats. Suspect that surge entered via the cable (on cable linked equipment failed e.g. DVR, Blue Ray player and TV) Power surge protected
Ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@stilllearnn
Samsung officially does not use blink codes. Your case sounds like a bad power board. You do want to disconnect every input source. Then disconnect the power cable. Hold the power button for about 30-60 seconds. Then plug your TV in and try to turn it on. If that does not work you will have to take the back of your TV and take a good look at the boards. Post some good images of those with your question. that will allow us to see what you see. Use this guide 在已经存在的问题里加入图片 for that.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for taking time for helpful reply. Power button hold did not help. I will open and post some photos. Again,thanks
完成的
添加一条评论
添加你的答案
Tom Retson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 125
