Can you give more details on your issue? I recently had a problem with my left Joy-Con, which would "drift", ie. would move upwards by its own and would not return/stay in its default, central position when untouched. Is this the issue you are experiencing?
If this isn’t a hardware problem. Then going to settings scrolling down to controllers and sensors. Then clicking on calibrate control stick select the stick you want to calibrate. And click y to go back to default settings. that should fix the problem
由 Louis 完成的
由 Chase 完成的
