跳转到主内容
The Shark Rocket HV301 is the second installment of vacuums in the 300 series. It is a two-in-one vacuum that comes with several attachments, making it capable of cleaning on different surfaces. Its sleek and lightweight design make it easy to maneuver around any household.
17 个问题 查看全部
No suction-not a filter or clogged hose
My Shark is a Rocket True Pet purchased from Walmart in 2015. Great vacuum until today. I vacuumed our hardwood floor of pet hair (maybe 15-20 minutes) and it did well. Went to vacuum a small carpet with dog hair and nothing. Running but not picking up. I've detached the main unit from everything and removed all filters. It turns on and sounds fine but no suction coming from tip. I see nothing else I can clean.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
评论:
MINE HAS A CRACKED HOSE IN THE CARPET FOOT ATTACHMENT AND i CANNOT FIND A NEW FOOT
完成的
添加一条评论
1个回答
最有帮助的答案
Most people miss this one:
Cause 1
Exhaust Filter
The exhaust filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner’s manual for cleaning instructions.
这个答案有帮助吗?
得分 1
评论:
Thanks but it's not a filter. With everything detached and removed the main unit turns on and sounds like it is working but has no suction.
完成的
添加一条评论
添加你的答案
varider424 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 16
总计 295
