跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
Lightly water damaged iPhone SE - issues with corrosion and speaker
I recently bought an iPhone SE from eBay in a lot of devices. The iPhone SE works, except there is corrosion near the battery connector, and the loudspeaker does not work.
The corrosion is in a small area to the right of the battery connector, it doesn't seem to cover any important components.
I was worried the audio IC was busted, but the earpiece and headphones work, so it seems to be a problem with the speaker itself.
I intend on saving the phone, because the water seemed only to affect the lower third of the phone. I replaced the loudspeaker with one from a working iPhone 5S, but the issue still continues.
In short, how do I tackle these problems and prevent the phone from further damage?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
how does the contacts look for the speaker on the charge port? Are they corroded? I would replace the charge port also as water can damage the wiring inside the charging dock connector!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eric Zhang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 145
