跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Why does an iPhone 7 not turn on with charging port plugged in
Hello, I had an iPhone 7 come in DOA. No signs of life, cracked screen, wouldn't take a charge. After opening the phone, it has no signs of water damage or anything visibly broken. I went through steps of diagnosing the issue. Started with new screen (no fix). Then connected a different battery, nothing. Then decided to replace the charging port. At this point the phone came on, but went into a boot loop. So I disconnected the charging port and reconnected the second battery, and the phone came right on with the original cracked screen. The replacement charging port is an OEM charging port. I am assuming the original battery that is still connected is just very dead as it obviously wouldn't take a charge from the original charging port. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
What happens when you plug the charging flex then plug a charging cable while the phone has successfully booted and is on the lock / home screen?
If the phone doesn't show charging response then it's definitely the Tristar chip.
If apple logo does not appear on either charging ports while battery is unplugged but charging cable plugged in it's the tristar as well.
这个答案有帮助吗?
得分 2
添加一条评论
Will the second battery take a charge after it dies? I have seen the tristar chip go out or start to fail, which causes this.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
matt mocciola 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 107
