跳转到主内容
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
208 个问题 查看全部
Will not power up No light
One day the mini would not power up.
Symptoms.
1: no power light
2: No startup sound.
As if the Power supply is bad and or or no AC power coming in.
1: How to test the power supply unit? ruling out the Mainboard.
2: I have inspected the main board to the best of my abilities and see no visible damage.
TIA
Sam
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Double check your outlet and power cord make sure both are working. If they are the likely hood is the power supply is gone. As for testing not very easy as you’ll need to fully remove it and probe the unit checking the voltages while its live which can be dangerous!
Here’s the IFIXIT guide: Mac mini Late 2012 Power Supply Replacement And here’s the needed part: Mac mini A1347 (Mid 2011-Late 2014) Power Supply
Update (07/01/2018)
@thesniper - With so little info its hard to gage ones skills and you didn’t offer what you had checked so I have to start off with the basics. As a reference here is the info from the service guide:
Mac mini A1347 (Mid 2011-Late 2014) Power Supply图片
产品
$79.99
这个答案有帮助吗?
得分 3
1条评论:
While I am gratefull for your time to answer. I was smart enough to check for incoming power. as well as continuity of the cable. I was hoping for a little more insight than "check for power". I dont believe the PS is gone. Im more suspect its the main board. but then again thats why I posted to being with. Thanks anyways.
完成的
添加一条评论
添加你的答案
Sam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 37
总计 2,338
