跳转到主内容
加入维修社区 - 创建账户
2014 年发布的联想游戏笔记本电脑,配备 Nvidia 860M 显卡和 15.6 英寸显示屏。2015 年更新为 960M 显卡。
Why won't my laptop charge?
My lenovo gaming laptop (Y50-70) is approaching four years of age and starting having charging issues last week. The computer would randomly stop charging at times for varying lengths of time. it could be 10 seconds to an hour of proper charging before it stopped. I decided to get a new charger to see if it was a charger issue but the computer is completely dead and will not turn on even when attached to the new charger.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This could be a few different things. The first being a battery. Depending on the computer it will not run off plugged power but only power from the battery, so if now power is going through the battery it won't come on. The second could be a port issue where you plug it in, if its damaged power may not be going through it. The third thing I can think of would be a damaged solder joint in the computer where the power leads hook up.
这个答案有帮助吗?
得分 0
2条评论:
Do you think I should just bring my computer to geek squad at Best buy and see what they can do with it? Because the problem is most likely internal from what I can see.
完成的
Sorry for the delay. It is worth having a professional look at it compared to the price of a new computer.
完成的
添加一条评论
添加你的答案
Anh Dai 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 1,553
