How to take laptop back to factory settings
i have a Toshiba Equium L20 - 197 Laptop serial number X5036405W with Windows XP and want to takeout back to factory settings BUT can only find a restore point not a factory settings
Obviouly some one has completely re-formated the hard drive and wiped Toshiba’s Factory Restore partition.
Just download and use the Mircosoft Product Key on the underside of the laptop or use , on the existing OS, one of the programs that finds the product key on the hard drive. Probably best to do both or find a used XP CD with a product key.
Just curious. Why do you want to do this?
这个答案有帮助吗?
Lost passwords to my 2 XP Professional systems. Cannot get past log-in using "Administrator" method or in Safe Mode Command prompt.
@rickruggieri At the Welcome Screen. Press <Ctrl + Alt + Delete> twice to load the user login panel and just click "O.K."
If that doesn't work look here, fgor example:
Shut down completely and then as soon as you power the device on start pressing the f11 button. Or press and hold the f11 button and it should open prompts to factory restore it.
这个答案有帮助吗?
Will this delete any existing data?
@rickruggieri Yes it will. Backup data first.
Here's how to do a factory restore:
The drive will be wiped clean when you do the factory restore. If you don't want to do that, do not proceed.
这个答案有帮助吗?
This doesn't work Ive tried this and it just continues to open up as normal. :-(
过去 24 小时: 1
过去 7 天: 32
过去 30 天: 135
总计 14,849
1条评论
Have tried the press the 0 keys this doesn't work
由 gill.prior 完成的
