跳转到主内容
A collection of guides and support to help with washer repair.
3468 个问题 查看全部
Only drains after power rest and leaving lid open
GE Washer
GTW460ASJ0WW
When I start a normal cycle the washer runs normally until it gets to drain and spin part of the cycle. It makes a low 'hum' noise and eventually stops.
If I unplug the washer for about 30 seconds, plug it back in, leave the lid open the washer drains on its own after about an hour (I think, could be hours). So the pump seems to work but its refusing to work properly during normal operation.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Your conclusion that the drain pump works is not substantiated by your statement that it takes an hour to drain. Rather it shows that the pump is not working and the drain may be partially clogged. Here are the things you need to look at:
Cause 1
Drain Pump
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Cause 2
Clogged Pump or Hose
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.
Cause 3
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not drain. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
这个答案有帮助吗?
得分 2
2条评论:
When I lay the drain hose on the ground it flows quite freely. It doesn't only drain after being left for a while but also the first attempt at running a cycle afterwards. Any subsequent cycles however do not drain.
完成的
OK if is draining when disconnected look further down the line. You may need to snake drain pipe.
完成的
添加一条评论
添加你的答案
Nick Coffin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 18
总计 1,316
