跳转到主内容
各种显卡维修指南。
42 个问题 查看全部
No video untill booted into windows
I recently upgraded the videocard in a 2-3 year old dell inspirion. Got the drivers installed, able to run games at a higher resolution and FPS. Perfect. One problem..I cannot access the BIOS settings, and the computer dosen't even give an output to my TV until I get to the spinning wheel before the sign in screen. Only possible fix is to have to swap back on forth video cards to access the bios. (which is not fun.) Is there a setting in windows that is enabled/dlsabled that shouldn't be?
EDIT: Link to a video that shows the issue: https://www.youtube.com/watch?v=XTN-Z32j...
Update (06/28/2018)
This is the image I get when I connect to the motherboard's built-in video output
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
Macbook 电池维修套装
起价 $69.99
Buy Now
Macbook 电池维修套装
起价 $69.99
Buy Now
1个答案
TV is the keyword here, i think you might be using HDMI and a TV does not reconise the signal fast enough. What could work is you boot into windows, then you press restart and then you might be able to get into bios with video signal.
这个答案有帮助吗?
按维修分数 0
评论:
Forgot to mention, I have the same problem when it's connected to a computer monitor too.
And even after hitting the key to enter BIOS, I try turning the tv on and off, reconnect the cable, nothing happens.
The reason when pressing the key to enter the bios you are met with a black screen.
Is because if you have a motherboard with on board graphics ports on it.
And also have a Pci-e card fitted.
Is because the bios out put is displayed on the on board graphics port of the motherboard.
Connect the monitor display cable to the back of the motherboard.
Then enter the bios, and change the default graphics card to be initialized to Pci-e first in the list.
Save the settings before exiting the bios.
Then move the cable back to the card in the Pci-e slot.
The next time you press the key to enter the bios it will be displayed on the Pci-e card.
Plugging into the motherboards built in port is no use...I just get a message that says this port is disabled. Keep in mind the pc is usable as seen in the link to the video I posted in the question, I just want to be able to acess the BIOS.
Okay, so if you use the pci-e gpu you might as well just disable the motherboard graphics. Access the CMOS/BIOS menu and disable onboard video, there should be a setting somewhere
显示更多的1条评论
添加一条评论
添加你的答案
Connor 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 52
