PS4 shuts down returning from sleep and won't start
Hi there, I am the proud owner of PS4 Model CUH-1216A.
When I turn it on it works fine then I send it to Sleep mode and it will turn on fine if it's not for a long time. But if I leave it be a day or two without playing it, when I try to turn it on the light goes from Orange to Blue and than to nothing.
After this if I try to turn it on the console will try boot the light will go Blue and than to nothing. This goes on and on.
To be able to play again I have to unplug the console and wait a couple of minutes. Then plug it in and it will turn on fine.
Also while this problem happens I can go into safe mode but I can't reboot into normal menu.
I had this problem before and I contacted Sony about it still with my warranty active. They suggested that I changed the power cord and this worked for like 4 months than the problem resurfaced. Is this a PSU problem? Or my Ps4 is Busted?
Or can it be that heat just ends up breaking my power cords?
I've seen my PS4 do strange things coming out of rest mode, but then I've only left it in that state for a maximum of a few hours. This doesn't explain your issue, but I'd shut it down if you're not using it.
由 cylentstorm 完成的
I get it, but I use remote play and having to get up from bed to turn ps4 on to play on the vita is a pain in the ass. Also charging the controllers is easier. I would like to fix this. I have a spare PSU in case it is a power supply problem.
由 Róbert Fekete 完成的
