跳转到主内容
24英寸显示器,内置iSight 摄像头,麦克风和扬声器。 1920*1200分辨率。 发布于2008年10月 型号为A1267
84 个问题 查看全部
Newly Replaced Power Supply Doesn't Power Logic Board
As the title states, I bought a brand new power supply for the display, but there is no voltage on any of the test points in the technician PDF.
I am measuring between these test points and the LCD screw holes.
Additionally, there isn't any voltage between these contacts on the power supply and the LCD screw holes.
Any suggestions?
Thanks,
Timothy
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @warkentim
Im not sure if the replacement powerboard is really working well,
IMO when i see the power board pictures, something has caught on my eye, it might be glue or flux,
but experts do feedback sometimes those glue can be conductive after some time of use, perhaps carefully scraping it off.
just check this, hopefully is not corroded or burnt components.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for the reply, I will try removing the glue when I get home!
完成的
添加一条评论
添加你的答案
Timothy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 157
