跳转到主内容
The headphone jack does not register my headphones
My PC wont register my headphones but they are plugged in.
This started out as a little thing but it built up into not registering the plug at all. The headphones work with my phone so they do work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
6条评论
Livewire
what computer is it or at least what brand motherboard? Separate sound card or are you using an onboard sound card?
Rep: 1
完成的
It has an integrated sound card but I'm thinking of getting a USB soundcard.
EDIT: I don't know what type of motherboard and my pc is pirated windows 7 and my rating is 3.5
完成的
Hi Livewire, can you check on your device manager, under sound , video, audio controller, do you see if the mainboard sound card is detected, like realtek, etc?
how about the rear connection? does it works?
完成的
It works sometimes but only through one ear
完成的
it has no audio controller
just high definition audio device
完成的
显示更多的1条评论
添加一条评论
1个答案
最有帮助的答案
without going into too many details or asking too many questions, as a tech the first thing you do is the simple things. so I would check the sound card drivers first. Otherwise it is looking like there could be something physically wrong with the jack itself . After making sure your drivers are good since you know the headphones are good, If you can open up your computer and see is there are loose connections or shorted wires and that sort of things. I apologize for not being able to be more helpful with this one. I really do hope that you resolve your issue without having to spend money
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Livewire 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,361
