跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
773 个问题 查看全部
Black screen is seen with flashlight and works with external display
Hello good morning, I just turned on my Macbook pro 15" 2015 model: A1398.
I was reneging for a while until I could see with a flashlight the log in screen, logged in and put in an hdmi cable, and everything is working except the screen that is still the same, in fact I'm sending this message from the macbook.
You know what it might be?
New Photos:
This is the code you asked me for: 820-5482-A
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
'''++Facundo Panizza++'''  you do want to go ahead and check the parts on your board. You need to get to the logicboard so follow this guide to get there.Use this guide MacBook Pro 15‘’Retina显示器2015年中期主板交换 for that. Check the board and see if it has an 820-XXXX number on it. this is important since there are a few variations. Take some good pictures of your board etc. and post those with your question. That will allow us to see what you see. Use this guide 在已经存在的问题里加入图片 for that. Check the display cable to ensure that it is properly seated and that the connector is not showing any damage on the pins. Then you want to start by checking the backlight fuse for continuity and check if you have power going to it. This will be tricky since you are going to power the computer on. Do not shorten other components out while testing it. Let us know what you find.
If unsure of doing any of this contact the experts @reecee and @tcrs_circuit to see what their take is on this and if they can help you further.
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
MacBook Pro 15" Retina Display Mid 2015 主板图片
指南
难度:
困难
1 - 3 hours
这个答案有帮助吗?
得分 3
6条评论:
I'm sorry for the long delay, I leave the data you had asked me hopefully serve something, not get to see any corrosion, just a few stains near the load pin
完成的
I think the 9700 fuse is not walking, because I used the multimeter and gives me 0, to use it with other fuses, gives me varied numbers
完成的
Facundo Panizza do not worry about any numbers. Just check it for continuity https://www.swe-check.com.au/pages/learn...
完成的
Well, it didn't give 1, say 0.00.
完成的
okay sounds like a bad fuse. Replace it and check the circuit since something caused the fuse to blow. Check your connector make sure there is no corrosion or damage on it.
完成的
显示更多的1条评论
添加一条评论
You’ll need to check the backlight fuse and you might need a new backlight LED driver chip as these tend to fail.
这个答案有帮助吗?
得分 1
添加一条评论
Hi Facundo,
To me it sounds like your backlight went out on your Macbook. I would look into a possible replacement, but before you order another one. I would check into seeing if it just came unplugged or the cable for it went bad. That way you do not waste your money on another screen if that was not the problem.
Best Regards,
Drew.
这个答案有帮助吗?
得分 -1
1条评论:
@takkaz what kind of backlight would you purchase for this and which cable may have gone bad?
完成的
添加一条评论
Screen light is burned out or inverter is out.
Will need repairing by a technician.
这个答案有帮助吗?
得分 -1
4条评论:
@charlied139 where is the inverter for this model and which screen light may have burned out? Can you elaborate on your answer?
完成的
@oldturkey03 Nice question =;)
完成的
@arbaman thank you for your support and for our great participation on our forum. You are an asset to the community!
完成的
@oldturkey03 Thanks a lot for the kind words, I really appreciate :))
完成的
添加一条评论
添加你的答案
Facundo Panizza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,075
