跳转到主内容
A smartphone by Sony released July 2012, available in black, white, and yellow.
7 个问题 查看全部
I need sim card diagram sulation for sony xperia go
hi
i have sony xperia go (st271) i changed my sim card slot but still there is no sim card error on the phone
one of those 6 jumper is missing (I'm not sure jumper is the correct name or not) so i need a full diagram of that part of the board to fix it
anyone can help me?
thanks a lot
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
https://www.youtube.com/watch?v=lmI7X0Nv...
Here is a complete video on how to fix your issue. Worked for my daughters phone. Good Luck!
这个答案有帮助吗?
得分 1
4条评论:
thanks for your help but this is different phone and i changed slot already and also that need another same board i think if i had the board diagram i could fix it
完成的
Sony Xperia Go ST27i Insert Sim IC Solution Jumper Problem Ways
in case of insert sim problem in Sony Xperia Go ST27i it will show insert sim, sim not valid, and may not show signal.to solve Sony Xperia Go ST27i Insert Sim IC Solution Jumper Problem Ways we have to do a few simple steps as given in this post.in first step replace you sim and try it.scratch sim points in mobile slightly then try.
[caption id="attachment_19576" align="alignnone" width="300"]Sony Xperia Go ST27i Insert Sim IC Solution Jumper Problem Ways Sony Xperia Go ST27i Insert Sim IC Solution Jumper Problem Ways[/caption]
after dis assembly check all sim jack points at mother board with meter.check all these parts and track that are given in above diagram and if any of them is missing apply jumpers to make that path in good condition.if any of the components is missing replace it with new.
完成的
you can change sim ic also and may can apply jumpers after removing ic from mother board.there are some posts also to describe that how to make jumpers in sim ic to solve insert sim problem.
完成的
thank you so much laura ... i did check all sim jack points at mother board with meter and one of them not work
完成的
添加一条评论
添加你的答案
omid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 454
