跳转到主内容
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
147 个问题 查看全部
Any way to read part of screen that’s broken during Apple HardwareTest
So I’m working on this reclamation project for this 13” 2010 MacBook Air. About 1/4th of the screen is broken, so normally I have it hooked up to an external monitor, which works fine.
Problem started when I replaced the keyboard recently after it’s power key stopped working. I did the replacement fine, the keyboard now works, but the computer is ghastly laggish when it’s doing anything.
I burned Apple hardware test onto a bootable USB, and ran the diagnostic, but the error code that it spits out is half-blocked from the screen damage. Bc it’s in AHT, the external monitor doesn’t work, and I can’t move the window to where I can see the whole code. All I can make out is “4SNS/1/40...” and that’s all I can see.
Is there anyway to figure out what the rest of that code is? I can’t seem to select text so copy and paste doesn’t seem to be an option either.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Print the screen or capture the screen and then print it.
这个答案有帮助吗?
得分 2
添加一条评论
I may be wrong @mayer correct me on this , but if you start the macbook up in clam shell mode you can see the diagnostics on the external display.
https://support.apple.com/en-gb/ht201834
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
vinet09 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 38
