跳转到主内容
The Polaroid A10, released March 2013, is a 10.1" Internet Tablet with an Android 4.1 Jelly Bean operating system.
4 个问题 查看全部
I don't remember my pattern. How do I reset?
I have not used my tablet for awhile and don't remember the pattern for security. How do i reset?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
If you forgot your pattern, your device probably have secondary option to retrieve or open back your device.
It could be your passcode or email field where to send you a guideline how to retrieve back to your device.
这个答案有帮助吗?
得分 0
3条评论:
Thank you, but I can't get anywhere on the tablet without the security pattern. And now I can't even get into the website. I logged in with Google but that's not an option now.
完成的
have you reached the maximum input number of your pattern? If you do, there will be a small text below where it will be linked to passcode section.
完成的
In case you can't see the passcode text... Please do follow this guideline:
Forgot unlock pattern and recovery email password
Hope it helps you.
完成的
添加一条评论
Yes but it crack in the of tablet it want let me lock it
这个答案有帮助吗?
得分 0
添加一条评论
If you have forgotten it, you might be able to factory reset it (but you will loose all your content and data) but this will allow you to use it again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Polly Myers 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 16
总计 952
