跳转到主内容
修复你的物品
维修的权力
配件 & 工具
6th generation of Honda's popular compact car.
49 个问题 查看全部
Do 1998's have this valve
My 1998 civic had a low idle so I cleaned the throttle body and the air idle sensor. The fast-idle thermo valve is my problem. I can not locate this part?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
2个回答
已选择的解决方案
Thank you for the quick response back and the knowledge that I couldn't fine anywhere on a video. I was about to blow the car up. There ended up being a vacuum leak that wasn't leaking the day before. Much appreciated sir.
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
'''++@mattbmenifee++'''
that depends what engine your Honda has. If the engine number (check your metal tag inside the engine compartment) starts with a D(16Y8 etc.) than it does not. D type engine did not use those after 1996. So to completely answer this we will need more information.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Matthew 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 47
