跳转到主内容
MacBook Pro exposed to inverse current
The power cord for my MacBook pro had broken again - the wires connecting to the converter were worn out - and I was reconnecting the wires. I'd done this repair a few times before so it was a routine process for me. Unfortunately, i was quite dimwitted when I was doing it this time and connected the white wire to the black one and vise versa. I plugged in the magsafe to my laptop with the wires crossed and exposed it to reverse current. Now my computer will not accept a change. The magsafe lights do not turn on when plugged in (with the power cord wires connected in the correct way. I tested the power cord on my brothers laptop and it works) so the issue is with my laptop. I immediately thought resetting the SMC settings would fix it but I've had no luck with that. The computer has been my trooper for the past 7 years still works fine aside from not being able to accept a charge. Any ideas on a repair? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Thanks Noah! I ordered that part and will let you know if it fixes the problem.
完成的
添加一条评论
1个答案
最有帮助的答案
Oh my goodness so sorry to hear this! Those Mag Safe chargers are so expensive I have also fixed a few over the years. Now, this is probably a isolated incident only affecting the DC-In module.
I suggest you go Here to buy a new one and replace it.
The guide for that is Here
Hope that fixes the problem, though I don't believe it would spread any further than that module.
Hope this works for you, keep us updated.
Cheers
Noah
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board图片
产品
$9.99
这个答案有帮助吗?
得分 2
1条评论:
Noah,
Thanks for the fix! I'm happily typing this on my newly charging MBP!
Andy
完成的
添加一条评论
添加你的答案
Andy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 53
