跳转到主内容
The Sony Xperia Z5 Android smartphone was released in October 2015. The Sony Xperia Z5 features 5.2 inches 1080 x 1920 pixels display and is equipped with a Qualcomm Snapdragon 810 processor alongside 3GB RAM and a 23 MP rear camera.
74 个问题 查看全部
My Xperia Z5 premium doesn't turn on, and the red led flashing
gents, please help me how to fix my mobile phone.
my Xperia Z5 premium doesn't turn on, and the red led flashing while plug the USB cable.
force restart and power with volume keys not work.
also, tried to use Xperia Companion but unfortunately my phone not able to contact with the PC.
do anyone has any idea about what's happening?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
Battery over discharged or given up. Have you plugged it in and left it for maybe an hour or so? Also try another charger/ cable if you can. If the phone is 2 or 3 years old the battery may need to be replaced.
完成的
添加一条评论
3个答案
最有帮助的答案
I had a similar issue, couldnt fastboot, POWER+VOLUME KEYS did nothing for me. Changing the chargers had different effects from red flashes, 3 red flashes and at times white sony screen flashes.
So I took it to the local shop and when they opened up the back cover, they found out that the battery connector had come loose. After pressing it back in, the phone was back.
Hope this helps someone.
这个答案有帮助吗?
得分 4
添加一条评论
Did you tried turning it on, on fastboot?
-Just press the volume down (No power button)
-Plug the phone into the computer while pressing that key
A blue light should turn on
这个答案有帮助吗?
得分 0
3条评论:
yes i did but no response
完成的
You never got the phone wet? (I know the z5 is waterproof, but sometimes the seal fails).
完成的
that's never happened mate
完成的
添加一条评论
Just had the same issue.
Tried to charged using powerbank, as I thought charging from power outlet didn't work. FAIL.
Then i opened the simcard cover, pressed the yellow button & power button at the same time for couple of seconds. maybe 3-4 seconds. Last one, put it on charging cable.
Voila, it charges & back to life.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
eng.mo3taz_surv 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 75
总计 7,069
