跳转到主内容
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
53 个问题 查看全部
Where is the intake air temperature sensor located?
My check engine light is on so I did a code check at my local parts store, the scanner said my problem is an intake air temp. sensor. My problem is I can,t find it. Please help. The reason I had it checked is because it takes me 30 min. sometimes to get it started. I've replaced fuel pump, air charged sensor, head work done, stopped the heating problem now I would like for it to start when I turn the key.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
trying to find IAT sensor on my BA 6cyl falcon auto
完成的
添加一条评论
2个答案
已选择的解决方案
chadell if you are looking for the physical location of the sensor, it is on the left hand side of your engine and all 4 cyl and 1998 models have the intake air temperature sensor installed in the air cleaner housing and it is only 2 wires. Check the attached image ;-) it also helps if you give the error code that you originally got.. anyhow here you go.
这个答案有帮助吗?
得分 3
2条评论:
Turkey - I realized after reading your answer that chadell may have been stating that he couldn't find it on the vehicle not that he couldn't find the part ;-)
完成的
mayer, happens to me all the time it just shows we are all humans ;-)
完成的
添加一条评论
Here you go: http://www.google.com/search?client=safa...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
chadell 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 24
总计 9,366
