跳转到主内容
Guides and support for various television (TV) brands and styles.
9048 个问题 查看全部
Tv wont turn on.
Tv was turned off with remote then had no power light that night. Two days later, green light showed then turned red. Turned on tv, light went green, nothing happened and light went off again. Held in buttons as suggested on this site and button showed green then red but when turned on, turned green again and seemed to want to turn on but went off and now no lights showing again. It says it's a AWA 24" FULL HD LCD with built-in DVD Player. Model number: MHDV-2413-03-D0 but AWA hasn't been manufacturing for years.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
@icabod this could b a fun task. Something rare for a challenge ;-) You do want to go ahead and remove the back of your TV. Then take lots of good pictures of all of the boards and the cables etc. Post those with your question so that we can see what you see. Use this guide 在已经存在的问题里加入图片 for that. Check the boards for any obvious damage like domed or leaking capacitors etc. Then you can go ahead with some troubleshooting but you will need a multimeter for that.
这个答案有帮助吗?
得分 1
添加一条评论
Hi.
1: plug out power connector, mains power, and leave TV with no power for a full night.
Sometimes, RAM or EEPROM needs resetting.
2: Remote has battery?
Hope this helps, if not it its the powersupply or mainboard of the TV.
Best
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Icabod 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 157
