跳转到主内容
This affordable large-screen Android phone sports a 5.7-inch display and large 3,400 mAh battery.
218 个问题 查看全部
bluetooth won't connect to devices
Turned on bluetooth to both phone and tablet but says no devices found even though they are both paired
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would take a look on each device at the ‘paired’ devices list. If you see the other device in the list, there should be an option to ‘forget’ that device. Do this on each device to clear them out. Then turn Bluetooth off and on on each device and try again.
Sometimes Bluetooth connections can be tricky and need a reset.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rosemary Reed 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 303
