跳转到主内容
Tape recording speed is ok, but playback speed is hapering
I have not exactly the same camera but a JVC GR-D340E with has a problem with playback. It seems that the recording speed is oke, but if I view what is recorded than there is a hampering in the tape speed. It plays a bit and with a very short interruption it continues. This repeats itself all the time and with every tape, including old tapes. What is causing the problem and how can this be solved?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Without seeing the "disruption" it is difficult to say with confidence what the problem is. however, if the unit is sufficiently mis-aligned, the tracking information may not be read from the tape and that would cause the playback to be somewhat random. Since this is a digital recorder (as opposed to analog), the missing data can show up in really odd ways.
Does a tape recorded on this camera playback the same way? If so, then have the camera serviced paying particular attention to the alignment of the tape. If a tape recorded with this camera plays back on this camera OK but other tapes recorded elsewhere do not, it again points to alignment being off.
Check this and update this posting with the results.
Dan
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pedro Zuiderwijk 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 250
