跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
keys on my MacBook Pro 2012 don't work properly!
I've asked here before about same issue and that was my post:>>>>>>
How could I fix my macbook pro keyboard? I have problem with some keys on my keyboard that doesn't work properly,After many tries I found that some keys together click another key like:`+z+=bringing up the volume level
`+x+c=( § )
`+x+c+v=( [ )
`+x+c+v+b=( ] )
`+x+c+v+b+n=( = )
`+x+c+v+b+n+,=( ⬅ )
`+x+c+v+b+n+,+.=( ⬆ ) anybody has any idea about what the problem and how to fix it??
after I did pop the bottom cover I realized that the two holders of the battery"sorry for my bad English" are broken as u could see in the image:
I thought then that the problem is the battery as someone replied to my first post,then I took out the battery and put the laptop on charger then I turned on the laptop without battery but the Keyes problem didn't solve!!!
what do you think then is the problem?the battery coz the holders were broken ?or the keyboard its self coz it didn't work when I took off the battery?
thanks a million in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The keyboard has gone faulty, and usually goes bad from liquid damage. Any liquid spilled on the keyboard will cause it to stop working.
You need to replace the keyboard which involves disassembling the MacBook to where you can remove the backlight layer of the keyboard without obstruction. There are about 50 screws you need to remove to take the keyboard out.
这个答案有帮助吗?
得分 3
1条评论:
The uppercase assembly is quite cheap! MacBook Pro 13" Unibody (Early 2011-Mid 2012) Upper Case And a lot less work!
完成的
添加一条评论
添加你的答案
mohammed demashqi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 84
