跳转到主内容
The PSP 3000 was released in the U.S. on the 15th of October 2008.
92 个问题 查看全部
Orange Charge Light Stays On (Dimly)
Orange Charge Light Stays On (Dimly) on my PSP 3000.
I have tried two batteries, one at full charge one at almost no charge. Same result.
Otherwise it seems to run fine.
Is this a problem? Any way to solve it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I tried a new power board, but the problem persisted. So what was it in the end? A loose connection, it seems, between the pad(?), the grey thing that runs from the motherboard , under the XO☐△ buttons and into the powerboard and the motherboard. When I pressed down on that cable close to the motherboard the charge light would go off. I disconnected it and reconnected it, and the problem went away. Thanks to all who read and thought about this question.
这个答案有帮助吗?
得分 1
1条评论:
Have the exact same issue and tried disconnecting and reconnecting the power strip. The light went off at first but came back after turning psp on and then off.
完成的
添加一条评论
最有帮助的答案
Does it glow bright when charging? If yes then probably a short/leak but not a bad one. Should be OK, though.
这个答案有帮助吗?
得分 1
4条评论:
Thanks for your reply. Yes it does, glows bright when charging and does not turn on when in standby mode. Would this be the power switch board or motherboard do you think?
完成的
This kind of small current leak would probably happen near the power switch, although it could happen somewhere in the motherboard too but it's unlikely.
完成的
Thanks again. Just one last thing, the same problem happens when I plug in the AC adapter without a battery! Orange light on dim, fickering a bit. Does this change your opinion? If not, I will try changing the power board before giving up. (^^)
完成的
I would still stick with the current leak answer, although you can try changing the power board to test it out.
完成的
添加一条评论
添加你的答案
suaviant 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 18
过去 30 天: 81
总计 8,005
