跳转到主内容
Western Digital My Passport Drive. USB 3.0 Portable External Hard Drive.
73 个问题 查看全部
Passport only shows with my left usb port, but right port isn't broken
My external drive isn't working with the usb port on the right side of my computer, but works fine with the left. Other usb devices work fine with the right port, so I don't know what the problem is. When I plug it into the right port, the power light on the external drive lights up and I can hear the components in it moving, but it doesn't show up anywhere. I checked disk management and it doesn't show up anywhere else. I suppose I could just keep it on the left side, but I since its attached to my laptop and not a desktop, I tend to move around a lot on that side and it comes disconnected, causing me frustration and loss of data if I haven't saved or backed up my data from a program installed on that drive recently.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Are you familiar with the color codes of USB port generations? wikipedia page on various USB standards Most USB externals being marketed these days are USB 3.0 but mine works fine on my USB 2.0 ports (although at a much slower speed). Check your ports and consult with your laptop documentation and you may find they are not all USB 3.0 ports and that could be causing your symptoms.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sarah Nicole 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 59
