跳转到主内容
A1706/EMC 3071—于2016年11月上市,这台13''MacBook Pro带有OLED触摸条。以双核“Skylake”英特尔酷睿i5 CPU和4个雷电3端口为特征。
238 个问题 查看全部
What attaches to the Touch Bar Cable?
In an effort to clean my logic board, I managed to tear the connector that connects TO the touch bar cable on the Macbook Pro A1706.
I couldn't simply replace the touch bar cable as this isn't the problem. It's the cable that connects to the touch bar cable.
Could someone tell me what part I require in order to replace this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Sorry to say Apple does not offer a replacement cable or even the touch bar. You'll need to replace the complete uppercase assembly ($$!!) You might find the part directly from China.
这个答案有帮助吗?
得分 1
2条评论:
I found some full touch bars online that I'll purchase - if I find that that's the part I require
完成的
Well, I found one source! For the part: Touch-Bar OLED Display Screen with Cable for A1706 MacBook Pro Retina 2016 I can't speak for the supplier, but its likely worth the risk.
完成的
添加一条评论
Is it a cable which connects to a controller, or to the Touch Bar itself? If it's a ribbon cable then you're out of luck, better replace the whole part.
这个答案有帮助吗?
得分 0
3条评论:
It's a little hard to describe but it's the chip/cable (not sure what it's called) that attaches to the Touch Bar Cable. It attaches to the chip part on the left side of the cable in the picture below
https://www.google.com.au/search?q=touch...:
From my understanding, it attaches to the Touch Bar - would this be correct?
What I'm trying to ascertain is what I'll need to change specifically. From what I've gathered, I'll need to replace the whole touch bar and that might solve my issue - hard to say and don't want to waste money buying a part that won't fix it.
完成的
Yep, ribbon connecting to the socket. Better off replacing the whole unit, but better match up part number, serial, etc to avoid buying a wrong one.
I never seen the internals, but does it come with the Touch ID? If yes, then don't risk it and (sadly) visit an Apple store.
完成的
The cable is not removable from the touch bar. You need to replace the entire part. Apple only offers the uppercase as a FRU which is quite expensive! Luckily the parts supplier of the touch bar display subassembly is able to sell them.
The Touch ID pad and its logic are a different part and that is easily removable so you can swap out the uppercase. Take a look at the IFIXIT teardown here: MacBook Pro 13 带 Touch Bar 版拆解 Jump to Step 11 for the scoop on the touch ID.
完成的
添加一条评论
添加你的答案
chrono 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 1,393
