跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Back Camera + Flashlight don´t work
Hello Community,
i have a problem with an Iphone 7 where the Back Kamera and the flashlight don´t work.
When i go to the Kamera App the screen ist black (Tested other Kamera apps too)
Also the Flashlight don´t work when i try to use it as light or something else.
The Facetime Kamera works well. I take the logic board to another iphone where kamera and flashlight is working. So it seems there is not a problem with the Camera and flashlight, more on the logic board.
Can anyone tell me where the controller on the logic board is that i can try to reball it?
kindly regards from Austria.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
There are several voltage rails supplying the rear camera. You should start by checking PP2V9_UT_AVDD_CONN (U2501) to see if it is properly supplying the voltage. If that looks okay, then check the power rails in the image below.
这个答案有帮助吗?
得分 2
添加一条评论
i had one with this issue as well. when u try to open the camera it was just black on the rear cam front still worked. also the flash said it was disabled and need to cool down. for me it was as simple as replacing the rear camera itself. it fixed both the flash and camera issue.
这个答案有帮助吗?
得分 0
添加一条评论
Maybe it's software problem... One of my family members got this problem with her iphone 6s but i think her problem is a hardware problem
DON’T TRY TO REPLACE THE CAMERA UNTIL YOU CHECK IF IT'S A SOFTWARE OR HARDWARE PROBLEM.. :)
这个答案有帮助吗?
得分 0
添加一条评论
I also experienced similar problem. It happened following to Display replacement ... the U shaped pin from right end of the camera connector on logic-board was detached from the PCB....
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Josef 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,227
