跳转到主内容
Released May 2015, identified by model number SM-T350. Features 8.0″ TFT capacitive touchscreen, 5 MP camera, Wi-Fi, GPS, Bluetooth.
118 个问题 查看全部
My Tablet is blinking when not charging or under 16%
My Samsung Galaxy Tab A is blinking. And it only happens when NOT charging or under 16% battery also it sometimes just shuts off by it self. I heard about fixes for "My tablet is not charging", but for me it's charging perfectly it's just blinking. Is there any fix or should i just get a new one.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
My Cabana image picture tab 9” flickering while charging and does not switch on. I don’t no if the phone is fully charge. Android 8
完成的
添加一条评论
2个答案
最有帮助的答案
This issue is usually caused by a physically damaged / worn charging port or the battery itself.
Charging port requires soldering so for that one you will need to take it to a repair shop that does Samsung Tablets.
For the battery it is user replaceable and fairly cheap to do. $15.
Here are link to parts and guide from iFixit:
三星 盖乐世 Tab A 电池更换
Samsung Galaxy Tab A 8.0 Battery
A red blinking notification LED light at the top left only when charging usually means that the device thinks that the battery temperature is too low.
This is usually a fault caused by a component like a thermistor (temperature sensor) in the charging circuit sometimes from liquid damage or damage on the charging port itself.
But I don't think that is the case as it would usually say 'Battery temperature too low. Charging paused' and the device would actually stop charging with a blinking battery icon.
Does it charge fine while it's turned off? anyway it's probably just the battery in your case.
Samsung Galaxy Tab A 8.0 Battery图片
产品
$16.99
这个答案有帮助吗?
得分 1
添加一条评论
It seems to be problem woth battery replacing battery would help and if not then please check by testing new screen on it.. but most probably its battery
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
David Raidd 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 15
过去 30 天: 46
总计 10,368
