跳转到主内容
修复你的物品
维修的权力
商店
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
457 个问题 查看全部
dim backlight after liquid damage
i have a macbook air 820-3437 which was liquid damaged, doa. corrosion was around smc and u7700, reballed smc and it turned on however dim backlight. is u7700 the issue or is there anything else i can check
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
评论:
@tcrs_circuit i replaced the backlight fuse as i wasnt getting the same voltage on both sides, however now it wont turn on at all, no green light on charger and no fan spin, i tried injecting voltage into pin to but it wont go past 0.05 amp on 8.5v
完成的
Sounds like something got messed up... Please tell me you didnt do this with power plugged in
完成的
do what test the fuse ?
完成的
添加一条评论
2个回答
已选择的解决方案
I'd definitely replace u7700, no wonder it might be the cause of the dim backlight. If you have corrosion in the area maybe there's some filth stuck under it. If you don't have a replacement try at least a reheat with quite a bit of no clean flux..touch it a little to confirm solder melting point, if it's just residues it might get cleaned and kick back in properly.
这个答案有帮助吗?
得分 1
评论:
replaced u7700 today with a new ic, still the same outcome. however checked the backlight fuse and even tho people say it never blows it looks discolored and im getting 8.5v at 1 side and 0.65 at the other so hopefully the replacement fuse arrives tomorrow to see if it fixes this issue
完成的
@tech_ni Are you sure the fuse didn't blow after driver replacement ? With such voltage in you shouldn't have any backlight at all, driver shouldn't be working. I don't second the view the fuse never blows, actually that's always first thing I check when there's no backlight.
完成的
i checked the fuse before replacing the driver aswell
完成的
@arbaman its not turning on now, im getting pp3v42_g3h, pp3v42g3h_sw, pp1v2_s5_smc_vddc. not getting ppbus_g3h
完成的
I see from your other comment you've replaced the fuse, right ? If that's the case you might have something shorted after the fuse that brings down ppbus. Remove the fuse to confirm and in case ppbus gets back to normal without fuse look for the short along the backlight circuit, not so many candidates luckily..
完成的
添加一条评论
This could be several things that are wrong. Probably the simplest solution would be checking the make sure all connections to the backlight and keyboard have the rust or calcium build up and if there is clean it using a cleaning brush, but be careful not to damage any connections.
这个答案有帮助吗?
得分 0
评论:
yea nick, smc and u7700 had corrosion, keyboard was fine. reballed smc to get power working again. think its the backlight fuse
完成的
添加一条评论
添加你的答案
daniel 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 115
