跳转到主内容
The Early 2009 Mac Pro—also known as the Mac Pro 4,1—introduced Intel's Nehalem architecture to Apple's line of professional desktop computers in March 2009. The Mac Pro 5,1 used the same interior design but received further CPU updates in 2010 and 2012.
201 个问题 查看全部
4,1 to 5,1 Firmware tool saying no internet access Solved
Having an issue updating Mac Pro 4,1 to 5,1 firmware. After following the instructions for set up (disable SIP, have 1.5 pkg on the desktop), when trying to run the firmware tool I get "This program requires Internet Access. Please connect your Mac Pro to the Internet and Try Again" even though I am connected with ethernet. I can not find a solution. Firewall on the Mac is off so I am at a loss. Can anyone help? (I am new to forum posting, please forgive any errors)
Update (05/26/2018)
I discovered that the replacement router I received from my internet provider a few months ago had the firewall settings to high. I set it to a lower level and the firmware tool worked right a way. Hope this can help someone else who may encounter this problem. Thank you as well to the member who responded to my question.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
最有帮助的答案
The information on this discussion of the problem may help solve your problems:
Installation of High Sierra 10.13 on unsupported Macs
这个答案有帮助吗?
得分 1
添加一条评论
I can confirm that the issue, if you have ruled out all possible chances your internet is actually not working , is in the router. I went loco with this !
这个答案有帮助吗?
得分 0
添加一条评论
Changing my router’s firewall setting to Low instead of Medium fixed the issue for me to. Thanks!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 1,207
