跳转到主内容
The Zoom Q3HD Handy Video Recorder is an audio and video recording device.
10 个问题 查看全部
Unit records only a couple minutes, then says card full
Records only a couple minutes, with a brand new card, then says card full.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @smokn6string ,
Has it worked OK before using the same capacity card as you are trying to use now?
Has it got the latest firmware installed?
这个答案有帮助吗?
得分 2
添加一条评论
I believe this SD card was ONCE  formatted by a different unit than the Video Camera.   IF you have a  SD card formatted , let say by your computer, even you format it again with the video camera, this card will NOT work on the video camera.  It will work for half a minute and indicated NO SPACE, card full.  That means the SD card cannot be formatted by anything BESIDES the video camera
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tom McMillan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 211
