跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Replaced iPhone 6S Plus charging assembly
Hello, I recently replaced the charging and auxiliary port assembly on my iPhone 6s plus using third party replacements parts. After replacement, the charging port works (the reason I replaced to begin with) however my auxiliary port plays out only the right half of the output. Is this due to a loose connector or faulty part? I've already tried wiggling the aux cord around to try and get contact for full audio but I don't even hear a partial buzz to indicate it's possible. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hello!
Chances are the part is faulty. Aftermarket chargeports have a high defect rate, as so many functions are controlled by this flex. I recommend purchasing an original flex off ebay that was pulled from a working iphone. I've never had any issues with a used original part.
这个答案有帮助吗?
得分 1
2条评论:
%#*@! I had guessed that was the case, I didn't even know their was a market for used parts though so I'll look into it, thanks man!
完成的
No problem! Doesn't hurt to double check and make sure your aux cord works fine with other devices
完成的
添加一条评论
添加你的答案
Solomon DellaPenna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 74
