跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Can't focus to close objects
Hello,
I have iPhone 7 32GB. After a while of using it, I find out that my camera glass is not okay. First I thought it's just scratch, but when I put it under a good light, it's visible that it's broken to two pieces (on the photo is visible only the thick scratch, but on good angle and light it's visible that it's broken to two parts).
I tried manual focusing, but from the beginning it's absolutely not focusing.
What to do? Remove camera glass?
Huawei P9 Lite doesn't have any problems with focusing it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello gamelaster,
This is a relatively easy fix. Because the lens seems to be cracked, it is causing focus issues because it cannot focus as it is like having a barrier blocking it from doing so. You will need to replace the glass. Luckily, this is very easy and I am including a video tutorial for you to follow if you want to try it yourself. I will also provide a link with the part needed. Just and FYI, if you do attempt to fix it, I do not take any responsibility if you damage or break your phone in the process. But best of luck!
Hope this helps!
Video: https://www.youtube.com/watch?v=TeDktasa...
Part: https://www.amazon.com/Bonafide-Hardware...
这个答案有帮助吗?
得分 0
2条评论:
I would encourage ay first time DIY fixer to remove the camera first, it is simple to do and will avoid the possibility of damaging the camera while you scrape away the glass with an exacto (yikes!).
完成的
Hello guys, thank you for replies. I will try it, and if I success, I will mark it as answer. Thank you for now!
完成的
添加一条评论
添加你的答案
Marek Kraus 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 751
