跳转到主内容
The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
20 个问题 查看全部
My dualshock's speaker got sprayed by some water droplets
I've got a problem wth my controller's speaker and willing to find solution
Yesterday my 7yrs old bro came out of nowhere and just for his own pleasure he sprayed me with godamn water,idk maybe he thought it was holly water,so i cleaned the DUALSHOCK4 with a tissue then continued using it(without thinking that it might have touched the speaker,lucky me it did!) so when i found out i left the controller lying on its face for a day and nothing chaned
Now lemme explain the issue
The speaker is working and makes sounds,and that's good,however What's bad is the sounds it makes,like when the DUALSHOCK4 is supposed to play romantic ear relaxing sound,it plays buzzing heavy metal sound
As an example when i play GTA5 and go over my phone and call any character the normal ringtone sounds lower than it should be and the buzzing starts(yes,like an earthquake in your hands),so shall i keep it lie that for couple of days or what?
Plz dont just ignore this post any past experience would help !
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi,
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the controller's operating design and could damage the components.
Rice is good to eat but it does not fix the problems caused by corrosion.
Don't Put Your Device in Rice. Here's Why...
First do not turn on your controller and then you need to with the controller turned off, remove the battery as soon as possible from the controller to minimize further damage.''
Then you need to dis-assemble the rest of the controller and clean all the affected parts using Isopropyl Alcohol 90%+ (available at most pharmacies) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA.
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the controller might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your controller, which may be of some help.
If this process seems too daunting, take your controller to a reputable, professional electronics repair service, experienced in water damage repair and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 1
添加一条评论
If it were me I would've put it in some rice when it happened, but sounds like your speakers done for, if it doesn't start working, you could just replace the speaker.
这个答案有帮助吗?
得分 0
2条评论:
Well it's working but it makes buzzing sounds
In GTAV it makes the sound that it's supposed tb o be played with a little bit of buzzing so is there's any chance that it may become normal again by it self?
完成的
Tbh this happened and I just used a dry toothbrush and got the water out and the speaker is fine now
完成的
添加一条评论
添加你的答案
mohamiid88 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 247
