跳转到主内容
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 个问题 查看全部
Slow Charging, 15% on 2 hours
Hi,
Im having an issue with an iPad 3.
- Already replace the dock connector, but the battery charges real slow, about 15% in 2 hours. Rested multiple flex connectors, issue persist.
Any one had encountered this issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It's probably battery related. However, before replacing the battery, try a known-good original iPad charger and Lightning cable to eliminate that as a potential source of problems.
If you have confirmed that the charger and cable are good, the try to replace the battery, following this guide, to see if that solves the problem. Otherwise, it could be a logic board/charge circuit issue.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Robert G 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 138
