跳转到主内容
megsafe T or L type for MacBook Pro 15" A1226?
The battery for my old MacBook Pro 3,1, 15", A1226 does not charge.
I use the 85W L-type charger. Is there a difference between the megsafe T or L type for it?
I only can use it connected with the megsafe, it always lights up green. Profiler says the battery has only about 140 cycles, but wont charge.
I already cleaned the connections etc.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Here's a good reference: Apple Portables: Troubleshooting MagSafe adapters and see if this is your problem: Portables: L-shaped MagSafe power adapter does not charge computer and LED indicator light does not illuminate
这个答案有帮助吗?
得分 0
3条评论:
oh, wow, the article of second link is very interesting, I didnt know that..
I just tried the SMC Firmware but installer says I dont need it, maybe because I'm on 10.6.8 already.
完成的
I don't know, but is there a difference between the height of the socket ?
There are two models of the Magsafe 85 Watt, the L- and the T-shape.
It seems that the original L-socket sits a tiny bit deeper in the MacBook dock?
Therefore the pins make better contact than the L-form?
http://fs5.directupload.net/images/18051...
完成的
The connector interface to the socket is the same. As long as you have the same wattage charger they are compatible.
完成的
添加一条评论
The Apple info page shows that only the T-shape is right for the late 2007 A1226 model I guess..
这个答案有帮助吗?
得分 0
2条评论:
The listing is what the system came with only! Both can be used.
完成的
ok, thanks..it is a bit misleading because the L-type is listed for the 2010 and up models..
完成的
添加一条评论
添加你的答案
Jamba 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 478
