跳转到主内容
Third generation of the BMW 3 Series / Also known as the E36
16 个问题 查看全部
I have no fuel and no spark
Drove my car home, had to jump the window switch to put my windows up, went back out in the morning to leave for work and all I have is cranking. Replaced fuel pump, fuel pump relay, ecm relay, ecm, and crank sensor, and It hasn't changed anything. I'm stuck please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
Get your car scanned for codes first. It could be your coils.
这个答案有帮助吗?
得分 3
2条评论:
Could they all go at once?
完成的
yes they can
完成的
添加一条评论
have you checked your spark plugs?
这个答案有帮助吗?
得分 0
添加一条评论
Honestly this could be CAS not communicating, or in your case EWS 2. Because of the age of these modules, they do have the tendency to fail.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ricky 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 30
总计 852
