跳转到主内容
The IdeaPad N580 is identified by the model number 20182. Released in August 2012, it has a 15.6” screen, uses the Intel HM76 core chipset, and comes equipped with 4GB of memory.
2 个问题 查看全部
Lenovo IdeaPad N580 cmaos battery
i need info on cmaos battery where it is n even if there is one for this laptop ty
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
最有帮助的答案
REF: https://data2.manualslib.com/pdf2/49/488...
The above link is to the hardware maintenance manual for your laptop. The parts list does not list a CMOS battery part number, nor can I find a reference to the CMOS clearing/battery. However, you can use the above manual to remove the motherboard and look for the battery.
这个答案有帮助吗?
得分 1
评论:
it was good in reference to taking apart the laptop but i think this is one laptop they desided not to tell where the cmos batter is i suspect its on the board itself ty again
完成的
添加一条评论
添加你的答案
Todd Miller 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 170
