This 10.1 megapixel digital camera has a 3.6x wide-angle lens, which can provide a wide field of view for panoramic pictures. It is also waterproof to depths up to 10 m (33 ft), freezeproof to temperatures down to -10°C (14°F), shockproof from heights of up to 2 m (6 ft) and crushproof up to 100 kg (220 lbs).
4 个问题 查看全部
showed red alert while using in water, now does not turn on
while using camera in water, it stopped taking pics. and showed "door opened" on it, even though battery door was shut, now it doesn't turn on. How do I know that it may be just the battery that may be damaged?
回答此问题 我也有这个问题
这是一个好问题吗?
按维修分数 0
添加一条评论
1个答案
Possibly a faulty seal or door catch. Open and remove all memory cards and batteries. examining closely for any sign of water inside the camera. Cut some thin card (cereal packet type) or paper into a strip. Gently and slowly insert the card/paper into the openings and try and get to all the corners. When you remove it look for damp patches on the card/paper. If it happened recently there will still be moisture inside. If there are any signes of water use the same technique for drying moblie phone you'll fine posted elsewhere. If you manage to get it working Don't use it in water again unless you manage to find the fault and fix it.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
judmar36 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 25
