Screen goes dim after 10 seconds.
Hi all,
I have a Macbook A1181 which starts up okay but after about 10 seconds (just after the apple logo appears on the grey background)the screen goes dim.
I can see the picture faintly on the screen and if I turn the screen brightness right down and then back up the screen is lit but then goes dim again. I've changed the inverter and the problem persists.
Is there a sensor or switch that may be at fault or could the screen be at fault?
Andy
10条评论
have you tried booting with your top case disconnected? If not, try that and let me know your results.
由 Josh 完成的
What happens if you try starting up and hold down the "Shift key"?
由 mayer 完成的
Hi Mayer. The same thing happens even when I hold the shift key down: grey screen, apple logo and then the screen goes dim. I haven't tried disconnecting the top case yet, though.
由 andyinwales 完成的
Hate to ask such a silly question, but did you change the Inverter cable as well or did you just replace the inverter?
由 Majesty 完成的
I dont think it's your reed switch cause that would put the Mac to sleep and you won't see any images at all o your screen.
由 Majesty 完成的
显示更多的5条评论
