跳转到主内容
Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
494 个问题 查看全部
Excessive oil filling air box from crankcase?
I have an easy go TXT gas golf cart with the Robin engine in it. I am getting excessive oil from my crankcase breather in to my air cleaner air Box? When it gets warm, I get Oil from my crankcase breather, up the tube and into my air Box, then into my carburetor causing a ploom of white smoke? Is my crankcase breather vent bad? When i soak it up with a rag it runs fine until it gets warm and does it again?
Thank you in advance for some info.
Tony.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I used to have a motorbike that did this. If your airbox has a drain tube in it. Unplug it and clean it out. It should dribble out merky oil. But they usually sludge up.
这个答案有帮助吗?
得分 1
添加一条评论
@ducatikid999 your engine should have a PCV valve. Replace that first and see if that helps.
这个答案有帮助吗?
得分 1
2条评论:
BINGO!!~ You just got it. 500.000 + Congratulations ;-) @oldturkey03
完成的
@mayer thank you Sir. Couldn't have done it without your support over the last 8 years!!!!
完成的
添加一条评论
添加你的答案
Tony 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 48
总计 5,021
