跳转到主内容
于2016年3月上市。型号 SM-G930V。
398 个问题 查看全部
Phone only works or charges with rear cover removed. Possible causes?
I replaced the LCD, battery and rear cover on this phone. I tested it before attaching the new rear cover, the screen worked, and the phone went through a charge and discharge cycle as normal. Then I replaced the rear cover and left it to sit under some slight pressure while the adhesive set overnight.
Next day the screen won't come on, and there's no indicator lights when I plug it into a charger. My USB ammeter shows it drawing only 0.17A -same as I've seen when this phone crashes or shuts down after a boot loop.
Has anyone observed this behavior before? What could cause the phone to work only when no rear cover is attached?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个回答
That is really odd.. it shouldn't matter if the back cover is removed or not. Is the battery or charge port damaged in any way?
这个答案有帮助吗?
得分 0
评论:
Not visibly at least. And when I was testing before replacing the rear cover it showed the expected charging amperage when plugged in.
完成的
添加一条评论
If you remove the back glass again will it power on? It is plausible that your adhesive may have got onto the motherboard and is shorting something? although not many adhesives are conductive.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stephen Barnwell 将永远感激不已
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 1
总计 49
