跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548 个问题 查看全部
iMac wont start-up. No video no start-up chime
iMac wont startup. No startup chime either. I can hear the CPU fan and some kind of "click" in the hard disk area. Sometimes (rarely) only a white screen. I cant start up form an external or dvd because nothing appears. I tried removing the ram, test one by one and with known good ones.
Any idea?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Your idea on testing the RAM was good. The next thing I would do is remove the frame so you can eyeball the diagnostic lights to the right of the RAM. There's really nothing listed to point to an answer yet. Did you hold down the option key when trying to start from an external or the shift key to try to start in safe mode? Do you have another Mac for Target Mode? Click on the step-by-step guides to your right to get to the frame guide.
这个答案有帮助吗?
得分 2
1条评论:
I did the option key when I started from an external har disk
完成的
添加一条评论
Bad Logic Board.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Flavio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,737
