跳转到主内容
The current line of iPod touch comprises seven (7) different generations.
2604 个问题 查看全部
How to restore iPod touch?
My boyfriend found an ipod touch. He did get the password which it was 2222, but now the ipod touch says ipod disabled please conect to itunes. I don't no what to do may someone tell me step by step. Please.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Did you connect it to iTunes. You will have to restore the ipod since the entering of the passcode disabled the touch.
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your iPod Touch to your computer.
  3. Select your iPod Touch when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your iPod touch's settings before restoring, you can select the Back Up option.
  7. Select the Restore option when iTunes prompts you. This is where you will lose all the information that is on your iPod
  8. Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up.
There is also another way but since you did not tell us what computer operating system you are using, it could be confusing to add this.
Hope this works and good luck.
这个答案有帮助吗?
得分 2
1条评论:
Could you please provide the other answer I have Microsoft and my itunes dont recognise my iphone 5 sadly I have the code but is disable can't enter it
完成的
添加一条评论
添加你的答案
paola 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 5,704
