跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
314 个问题 查看全部
Didn´t load in Stand-By
First,sorry for my english ;-)))
My sons ds only loaded if he is on.if the ds is off /in stand-by he did not loaded??????
THX
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
what will not load? the games? if you like to ask in your own language that is ok, we can use translation tools to help us. :-)
完成的
The Battery / Accu did not load....the game loading is no problem....If the D S Lite is on it will load, only if the DS is Off it would not load,
THX
完成的
Yes i try it open and closed but it did not load in stand-by/ Off
完成的
添加一条评论
1个答案
已选择的解决方案
You are saying that it turns on. It will load a game when turned on, after you select the game. If I am understanding correctly you want it to load the game at the same time as it is being turned on. There is a setting that you can change to make that happen. The instructions are in the manual. The manual can be downloaded here: http://www.nintendo.com/consumer/manuals...
If you are telling us it will not turn on please tell me does the orange charging light come on when you charge it? Does any of the screens or green power light flash on, then off, when you turn it on? Does the green power light come on and stay on but no screens turn on?
If I am not understanding you. Please tell me your language and express your thoughts in your language. I have an interpreter on my web browser.
这个答案有帮助吗?
得分 0
4条评论:
there are also others here who speak other languages ;-)
完成的
I have only problem with the charging.If the DS is on he will charge.If he is off there is no charging possible.No LED will light....
完成的
When it is turned on the orange charging light will come on when you charge it. No orange light when charging when turned off. Am I correct with this? Have you tried charging it with the DS open but off?
完成的
Yes i tried it open and off but nothing happened....
THX
完成的
添加一条评论
添加你的答案
eric 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 837
